Mechanics
CHEVY THERMOSTAT LOCATION
2001 Chevrolet Impala
Engine Cooling problem
2001 Chevy Impala 6 cyl Front Wheel Drive Automatic 233000 miles
From the diagram in a previous answer it looks as though the Impala's thermostat is located inside of where the radiator hose slips onto part of the manifold that comes from the engine block. If this is correct how do I remove and replace the thermostat.
Thank you in advance,
FülniX
Fulnix
November 1, 2010.
On a 3.8L V6, it is very simple. Follow the upper radiator hose to the manifold just in front of the throttle body. Loosen the hose clamp, pull the hose off of the " gooseneck". Loosen the 2 10mm bolts (deep 6 point socket works best). And off it comes! Clean the surfaces and re-install new one.
It also helps to disconnect the 5-6 local sensors so that you can pull the wiring harness out of the way. There is also a vacumm line that you can pull off to help with clearance. Be gentle with the vacumm lines as they become brittle with age and heat over time.
$8-$16 for a new themostat and gasket.
Is this a 3.4 or 3.8L engine?
Rasmataz
Nov 1, 2010.
This is a 3.4L
Fulnix
Nov 1, 2010.
This is the link
http://www.2carpros.com/forum/2002-chevy-impala-overheating-vt517048.html
with a picture i found in another thread. it is labeled thermostat location. The only thing I see disconnected is the radiator hose. But I'm assuming the 2 10mm bolts your talking about are on the manifold that has the "goose neck" on it. Is this correct?
Thank you again,
F lniX
Fulnix
Nov 2, 2010.
Yes, as the diagram below shows, there are 2 bolts needing to be removed from the tstat housing..
http://www.2carpros.com/forum/automotive_pictures/261618_0996b43f8023075a_1.jpg
Thank You for all your help. I bought the Thermostat and am going to replace it tomorrow. One more question. Is there supposed to be a gasket the goes between the manifold and the engine block or just the rubber round one that is already on the thermostat?
Years ago I replaced one on my 93 Chev Lumina and I think I remember that car had a gasket that went on the manifold. Just want to make sure I have anything.
Thank You again for all your help.
AD
Fulnix
Nov 2, 2010.
The thermostat gasket is the kind of thick round gasket on this vehicle, that is it.
AD
