2005 Chevy Equinox engine wont start
2005 CHEVROLET EQUINOX
45,000 MILES • 6 CYL • FWD • AUTOMATIC
MIGUELM36
The engine turns but it wont start. Battery is good, starter is good, power is good. We do not hear the usual sound that the fuel pump creates when you turn the key to the on position. What should I check for? Should I connect a scanner and find a trouble code? or check for fuel pressure somewhere in the engine compartment. I thank you for your response.
Dec 24, 2009 at 3:29 AM
