Steering is exceptionally loose and vehicle wanders really bad. Have replaced outer tie rods, ball joints, cv halfshafts and sway bar links. There is play in the left inner tie rod, but not from the rod itself (at least it appears that way). It appears that the whole assembly moves which I'm pretty sure it shouldn't at all. I have had issues with the rack and pinion on other GM cars, however, the symptons I'm experiencing don't seem to be the same as those I've seen before.
Feb 2, 2009 at 1:52 PM
