1991 Chevy Corsica HELP!
1991 CHEVROLET CORSICA
120,000 MILES • 6 CYL • FWD • AUTOMATIC
WAYNE UNDERWOOD
The car was running on 4 of 6 cylinders, replaced 2 of 3 ignition coils, now running fine. When you put it in drive it idles fine, as soon as you give it the gas it acts like it is not getting gas or trans is locking up and it dies. If you put it in park, give it gas, more than what is needed, and put in into drive, it will go with out any problems, but this is very hard on the trans. If you do this 2 or 3 times the car is fine. Is there a senor that needs to be adjusted on the trans? This happens even if you let the car warm up for 10 to 20 minutes. HELP!
Mar 1, 2008 at 9:04 PM
