Engine Mechanical problem
1991 Chevy Corsica 6 cyl Front Wheel Drive Automatic
When starting the car, after turning the key the car starts but when you release the ignition key the engine quits. Have checked fuel pump pressure, crank sensor, - replaced throttle position sensor but will not continue running after releasing ignition to run position.
Sep 10, 2010 at 3:41 PM
