After jumping another car my car's transmission will not shift into third gear. And the speedometer does not work either
Sunday, February 14th, 2010 AT 4:10 PM
BASSTECH
MEMBER
The ground wire from pcm (the aluminum part closest to the fuse box not the larger pcm case) to a screw or nut perces to bare metal its amazingly easy fix!
SPONSORED LINKS
Monday, February 15th, 2010 AT 4:38 PM
SKATRIPP
MEMBER
1 POST
Great info I found the problem all fixed now I love this site.
Monday, March 14th, 2011 AT 11:40 PM
CGOR
MEMBER
1 POST
2007 CHEVROLET COBALT
4 CYL
2WD
AUTOMATIC
42,000 MILES
Jumped battery off. Now check engine light is on and transmission is stuck in 1st gear. Thanks.
Monday, March 11th, 2019 AT 5:04 PM
(Merged)
MECHANIC
If the check engine light is on, you need to have it scanned to see what trouble code is stored in the computer. Most nationally recognized parts stores will do it for free. Chances are there is a problem with the vehicle speed sensor (VSS). Why it happened when you jumped it is hard to tell. Regardless, have the computer scanned for codes and it should identify where the problem is.
