Here is information on possible causes:
Engine cranks but will not start:
When the engine cranks normally but will not start, you need to check ignition, fuel and compression. Ignition is easy enough to check with a spark tester or by positioning a plug wire near a good ground. No spark? The most likely causes would be a failed ignition module, distributor pickup or crankshaft position (CKP) sensor.
A tool such as an Ignition system simulator can speed the diagnosis by quickly telling you if the ignition module and coil are capable of producing a spark with a simulated timing input signal. If the simulated signal generates a spark, the problem is a bad distributor pickup or crankshaft position sensor. No spark would point to a bad module or coil. Measuring ignition coil primary and secondary resistance can rule out that component as the culprit.
If you see a good hot spark when you crank the engine, but it will not start, check for fuel. The problem might be a bad fuel pump.
An engine that has fuel and spark, no serious vacuum leaks and cranks normally should start. The problem is compression . If it is an overhead cam engine with a rubber timing belt, a broken timing belt would be the most likely cause especially if the engine has a lot of miles on it. Most OEMs recommend replacing the OHC timing belt every 60,000 miles for preventative maintenance, but many belts are never changed. Eventually they break, and when they do the engine stops in its tracks. And in engines that lack sufficient valve-to-piston clearance as many import engines and some domestic engines do, it also causes extensive damage (bent valves and valve-train components and sometimes cracked pistons).
Jun 16, 2021 at 3:33 PM
