Blinkers not working
AMPHOME
  • 2004 CHEVROLET CAVALIER
Electrical problem 4 cyl Two Wheel Drive Automatic 27800 miles
My car was making a weird but fairly faint high-pitched squealing/squeaking noise anytime I was moving, seemed most prominent around 35-45 mph, which stopped if I even touched the brakes or cut the wheel even slightly to the left. Then one morning, the noise was gone, but the blinkers don't work at all. When I 'turn on' the blinkers, there's no clicking noise, no flashing light either internally or externally, no response at all. Fuse seems fine. Ideas? Also, the car has intermittently had issues with the speedometer and tachometer getting "stuck" and registering varying reading/speeds much higher than average. That problem might only last a day and resolve the next time I crank up... Or it might last a week or more and the gauges seem to almost 'deflate, ' meaning that the needle is a little lower each day until they return to normal. Do I need Holy Water?
Wednesday, October 15th, 2008 AT 9:24 PM
LEGITIMATE007
  • 5,121 POSTS
Lol, your first problem, is that you'll need to replace the "flasher fuse" which is usually a silver round or yellow, black rectangular plastic fuse usually located under the dash next to the steering column or in the fuse box itself. Your other problem with the speedometer, youll need to check the connection of the vehicle speed sensor or you may have to replace it. They are usually located right on the transmission
Wednesday, October 15th, 2008 AT 9:50 PM
LEGITIMATE007
  • 5,121 POSTS
Oh, yes, that squeeling noise may be your brake pad sensors, indicating that they need to be changed. Have it inspected
Wednesday, October 15th, 2008 AT 9:57 PM
LEGITIMATE007
  • 5,121 POSTS
At last and finally, your axles may be at fault, over the years the cv joints be come pitted and loose causing them to bounce back and forth, making a vibration in the steering wheel. They will need to be inspected/replaced also
Wednesday, October 15th, 2008 AT 10:08 PM
KERI ENGVALL
  • 4 CYL
  • 143,106 MILES
First my blinker and hazards went out, then my auntie replaced the fuses a week and a half later now the blinkers and the brake lights stopped working. Last night tried everything? What to do I have to do? I have low income. Please help. Thank you.
Monday, August 14th, 2017 AT 2:11 PM (Merged)
DHEPP
  • 2002 CHEVROLET CAVALIER
  • 2.4L
  • 4 CYL
  • FWD
  • 117,000 MILES
I have also been unable to find any broken wires or fuses. Hazard lights flash normally but again nothing on left rear.
Saturday, April 25th, 2020 AT 5:05 PM (Merged)
HMAC300
  • 48,601 POSTS
I'm assuming you have tried replacing bulb. Check yellow wire with t/s on and see if it 'gets power if it doesn't check to make sure black wire grounds it can be a bad socket if no power it may be the multi function switch
DHEPP
  • 2.4L
  • 4 CYL
  • FWD
  • 117,000 MILES
I have a 2002 cavalier 4 dr that the left rear turn signal and brake light quit working. Noticed when flasher started working twice as fast as it should. Replaced bulb with proper part and no change. Was told it was probably the turn signal/ light switch. Replaced that. Still no turn signal or brake light. Only thing that works is the marker light. Right side is all working. Where do I go from here?
Saturday, April 25th, 2020 AT 5:06 PM (Merged)
JDL
  • 16,098 POSTS
Does the high mount brake lamp work? The rear turn and brake lamp use the same bulb filament, just not at the same time. Did you check for voltage anywhere, use a test light. Did you try pushing in on the bulb a little, to see if makes good contact, with either the brake or turn signal on?
At the left rear, when activated, the yellow wire is voltage, check for voltage. The black wire is ground, check that also. The brown wire is for tail lamps.
The problem could be in the wiring circuit, somewhere. Let us know about voltage and ground.
Sometimes when checking the turn signal switch, You can use a jumper on the proper circuits and make them turn signals dance. That way you will know the wiring circuits are ok.
DHEPP
I had checked voltage at the socket. Marker light had power, had good ground, but nothing out of the brake/ turn signal. High mount light worked and everything on the right side works. Turns out the more I read online about people with this same problem, the more the socket itself was the answer. I unplugged the socket from the wiring harness and checked power again. All good. Then switched the right side socket for the left side and it works fine. Now I have to get to a Chevy dealership to hopefully get new socket as none of the parts stores carry this part. Thanks for your help.
JDL
  • 16,098 POSTS
I saw a turn signal lamp socket at rockauto. Com, about 37 bucks and change. That sounds a little steep to me? I haven't done a web search for that part? Have you thought about checking your local salvage yard?
JDL
  • 16,098 POSTS
Just to add, found some turn signal sockets on ebay, says it fits cavalier. Well less than 20 bucks, check it out.
HOMER5
  • 4 CYL
  • FWD
  • 140,000 MILES
My daughter's 2002 Chevy Cavalier is having a strange problem. Her rear turn signals, brake lights, and rear hazard lights do not work. All the lights stopped working at the same time. We have checked the bulb and fuses and there is no problem with those. Any ideas. Thanks.
DOCFIXIT
  • 18,828 POSTS
Hi
Does High Mount brake light come on? If yes then fault is in turn signal switch
Hope this helps
Thanks for donate
HOMER5
Thank you yes the high bar brake light does still work. Any tips for changing the switch. Thank you, thank you.
DOCFIXIT
  • 18,828 POSTS
Disable air bag will need to remove steering wheel need a puller. Also if tilt steering will need another tool. May need to loosen column mount bolts to gain room to pull wires out of column.
HOMER5
To disable airbags do I just pull the fuse and disconnect the battery and wait 10 minutes?
DOCFIXIT
  • 18,828 POSTS
Remove trim panel from under colum see diagram dis conect Yellow wire at connector this will dis able bag.
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_461.jpg
GERALDW
  • 4 CYL
  • 187,000 MILES
My driver side front turn signal is not working. I cannot see how I access that area to change it. The rear bulbs were easy to access.
BLUELIGHTNIN6
  • 16,542 POSTS
First, pop the hood. Remove the black radiator cover by prying up the 5 or 6 plastic pins holding it down. Then unscrew the two bolts holding down the headlight assembly. You should be able to maneuver the headlight/corner light assembly out now (they are connected). If not, take a long screw driver and put it in the hole whenere the corner light meets the headlight. You will see where they snap-on together. Un-snap them with the screwdriver and now they will definately come out from the car. Twist the light socket from the housing and replace the bulb.
JUSTDON
  • 150 POSTS
Electrical problem
2002 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
Both tail lights work when the headlights are turned on. However, the left turn signal, hazzard flasher, and brake light do not work on the driver side.
Everything works fine on the passenger side. Also, when the left turn signal is activated, the front flashes very fast but nothing at the rear.
Please help!
