where is my oil filter located at?
2000 CHEVROLET CAVALIER
5,000 MILES
BEANER BATTER
im tryin to change my oil but i cant locate my oil filter i have my car jacked up in the street right now
Jan 9, 2012 at 10:39 PM
FIXITMR
  • CAR REPAIR CONTRIBUTOR
  • 9,990 POSTS
Hello
The oil filter is behind engine on the passenger's. Here is a step by step guide to help you change it with a diagram below to show the filter location.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Jan 9, 2012 at 10:57 PM
SANDRA GEORGE
I can not seem to find where the oil filter is on my 2000 Chevy Cavalier.
Feb 9, 2019 at 8:46 PM (Merged)
Its located at the backside of the engine (between the engine and firewall) nearest the passenger side. You can get to it from under the hood
SATURNTECH9
  • 30,869 POSTS
You casn see it in the diagram i posted.
BOBBOTG2005
  • 7 POSTS
Where is the oil filter on a Chevy Cavalier 2002 2.4L engine VIN T located? Thanks
https://images.2carpros.com/forum/automotive_pictures/451804_engine2_4.jpg
BLUELIGHTNIN6
  • 16,542 POSTS
The oil filter on a 2002 Cavalier is located in the front of the motor. There is a black plastic cap that has a 1 1/4" nut attached to it. You need to remove this plastic cap to get to the paper filter. It does not have a metal canister like most filters. It's an internal filter. To find this black cap look just to the left of the power steering fluid container and down.
BOBBOTG2005
  • 7 POSTS
[quote:5579602ba0="bluelightnin6"]The oil filter on a 2002 Cavalier is located in the front of the motor. There is a black plastic cap that has a 1 1/4" nut attached to it. You need to remove this plastic cap to get to the paper filter. It does not have a metal canister like most filters. It's an internal filter. To find this black cap look just to the left of the power steering fluid container and down.[/quote:5579602ba0]
Thanks Bluelightnin6 appreciate your response. Ill check it out.
GEORGE WOOD
Engine Mechanical problem
2002 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
can you tell me where the oil filter is located in my 2002 chevy cavalier
Look at the pass side front of engine underneath. You may have to remove a shield to get to it
KCCDOUGLAS
I have a 2003 Chevy Cavalier LS/Sport coupe with a oil filter located on the top of my vehicle next to the engine, I am wondering if anybody can tell me how to remove (what tool I need) the black plastic oil filter cap, So I don't have to keep going back to dealerships that want to charge me WAY more then they need to. Thanks for the help.
SERVICE WRITER
  • 9,123 POSTS
You need an 1 3/8" socket and an extention. Just break the seal with the socket and extention, and then turn it off by hand or you'll encounter the fine engineering that will not allow you to remove the socket.
Verify the size at the parts store when you buy it.
