1997 Chevy Cavalier fuel pump and relay
1997 CHEVROLET CAVALIER
103,000 MILES • 4 CYL • 2WD • MANUAL
FRVP
Fuel pump started making lower sounding noise when priming and wouldn't prime after a while. Let is set over night and it primed once and ran it for an hour, but didn't prime the rest of the day. Did this same thing for 3 days, but now it never primes.
Checked fuses and swapped relays and tired to jump pin 87 to 30 and still would not prime. Testing the fuel pump relay socket I get strange readings on pin 87, which I believe is the input pin from the battery, pin 30 is output. When I tested the AC relay socket I get 12V on pin 87, but get strange readings like 25V sometimes more on pin 87 on the fuel pump relay socket.
I know what a job it is the replace the in-tank fuel pump, I replaced it 4 years ago. This time it has a full tank of gas. I'm almost sure the fuel pump has gone bad but want to fixed the cause of the problem this time. I replaced the fuel filter.
I don't want to ruin another fuel pump and these readings are worrying me. Any ideas?
Jun 24, 2010 at 6:13 PM
