1996 Chevy Cavalier misfire
1996 CHEVROLET CAVALIER
103,000 MILES • 4 CYL • FWD • AUTOMATIC
AARON YOUNG
My car is misfiring.Ive had problems with the coil packs twice before. Its runs smoother sometimes but it only gets about a quarter throttle and then it cuts out. I have a oil leak on the timing chain cover also.Is there any minor tests or sensors I can check.
updated 3-22-2010
96 Chevy Cavalier 2.4 L does it have a nox sensor? The code scanner says the nox # was jumping around at an idle and even with the engine off but ignition on.
Feb 26, 2010 at 5:33 PM
  • CAR REPAIR CONTRIBUTOR
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
Feb 26, 2010 at 5:46 PM
NODNARBROX
[quote:2bf98f3d8f="Aaron Young"]1996 Chevy Cavalier 4 cyl Front Wheel Drive Automatic 103000 miles
My car is misfiring.Ive had problems with the coil packs twice before. Its runs smoother sometimes but it only gets about a quarter throttle and then it cuts out. I have a oil leak on the timing chain cover also.Is there any minor tests or sencors I can check.[/quote:2bf98f3d8f]
The Crankshaft position sensor Check it they tend to go bad on these models its by your coil packs
Feb 27, 2010 at 2:51 PM
If you are refering this nox # as the knock sensor it has one its job is to retard ignition timing when it senses detonation/pinging/vibration, Its located on rear side of cylinder block.
Also check the CPS as suggested
Mar 22, 2010 at 6:07 PM
RENEGADE65
  • 29 POSTS
CKP crankshaft position sensor or ICM
Jan 4, 2013 at 1:22 AM
