1994 Chevy Cavalier Cranks But Wont Start
1994 CHEVROLET CAVALIER
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
SCORPIO1948
The car was running fine, i washed the engine, it wouldnt start until everything dried out. Then i started it and it ran fine, turned it off, the next time i tried to start it, it would only crank and not start and the dashlights and signal lights will not work. Then it started and ran fine until i turned the car off again, and the next time i tried to start it, it did the same thing, would not start. I replaced the crank sensor, the module, and a new fuel pump. The car wont start. When i was using my test light to test the wires i hear something click and then my dasklights and blinkers would work, so i started the car and it ran fine, do i pulled off all the new stuff (except fuel pump) and the car started and ran fine for a day, then the next day it would not start again. Everything works except dashights and blinkers.
Oct 30, 2009 at 4:12 PM
