2001 Chevy Camaro Engine won't start
2001 CHEVROLET CAMARO
84,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHEVROLET_17
I started my car and it ran very rough for about 10 seconds and hasn't started since. The battery, fuses, coil, starter, wires, and relays are all good. when I pulled the spark plugs out they were covered with a gas mixture and when it did start there was white smoke around the intake. Any ideas?
Apr 3, 2010 at 2:01 PM
  • CAR REPAIR CONTRIBUTOR
Hi Chevrolet_17, Welcome to 2carpros and TY for the donation
Check the fuel pressure if its within specs if okay. Clean out the idle air control valve and EGR valve to include testing the coolant temperature sensor,throttle position and manifold absolute pressure sensor.
Apr 3, 2010 at 2:23 PM
