Electrical problem
1992 Chevy Camaro 6 cyl Two Wheel Drive Automatic
Fuel pump inop in normal mode. Using prime wire, iI get fuel. Tried new relay, no help. I get zero volts at all pins on the relay. All fuses in fuseblock are good. Is there a fuse or cut out that I'm missing? Or shopuld I check something else?
Dec 2, 2009 at 7:23 PM
