Engine not cranking. not sure if its starter or?
1992 CHEVROLET CAMARO
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
AXL420
  • 5 POSTS
My 92 camaro just died while I was driving. I tried to restart it, but it just "clicks" I tried to jump the solenoid with a screwdriver, but when I did that the wheel inside the starter just spun. Didnt sound like it was engaging the flywheel. I'm really hopin the engine isnt seized up
Apr 10, 2009 at 7:36 PM
  • CAR REPAIR CONTRIBUTOR
Maybe the starter drive is too far from the flexplate and needs shimming or its engaging the engine but starter overrunning clutch is slipping.
This guide can help us
Apr 10, 2009 at 7:42 PM
AXL420
  • 5 POSTS
it really does seem like a starter problem. the only thing that is throwing me off is the way it just died. i know the car was low on oil, but it wasnt bone dry so i dont see why it would've seized up.
Apr 10, 2009 at 7:54 PM
Try turning the crankshaft 720degs if it does than its not seized up
Apr 10, 2009 at 7:58 PM
AXL420
  • 5 POSTS
thank you so much for your help. i'm goin to get the car towed back home now. wish me luck. lol
Apr 10, 2009 at 8:54 PM
ALTHEAME
Engine Mechanical problem
1992 Chevy Camaro V8 Front Wheel Drive Automatic
My son's camaro won't start. He has gas in it but when he turns the key in the ignition, the car just makes the sound like it starting up but never actually "catches" and starts.
I know this is sketchy info but I'm wondering if you can give me some ideas of what he might check.
Apr 7, 2020 at 11:59 AM (Merged)
Do below and comeback with some results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
MDEPAOLO
  • 9 POSTS
I have a 1992 Chevy Camaro (V8). When I turn the key to crank the engine, it cranks very slowly (one crank every few seconds) and sounds nowhere near what it should when a normal engine cranks. It will eventually turn over out of the blue after a while (like you are not expecting it to turn over and all of a sudden it does). Basically the crank sounds very weak and like I said very slow in between. The engine already idles low (500-750) and not sure if that has an impact on this problem. One other thing to add is that this crank problem seems to happen more often if car is warm when attempting to start and has been started recently.
Thank you for any input, this is my brother's car and he is in dire need of any outside input.
JETSA
  • 117 POSTS
Starter worn out, weak battery, poor connection of the battery cables comes to mind. Any of these are common causes of that condition, however worn out starter sounds most likely especially since you said it does it worse after a heatsoak (after driving). Might whip into an Autozone and let them do a free check while its happening.
RED_WING45
  • 33 POSTS
Electrical problem
1991 Chevy Camaro 6 cyl Two Wheel Drive Automatic
i have a 91 camaro, i put a starter in it wont start. the guy got a key cut, he said from a dealer. whats wrong help. ty john
MERLIN2021
  • 17,250 POSTS
John if you can give me a biit more info, I need to know if it cranks? Or does nothing?
RED_WING45
  • 33 POSTS
hi, john here my 91 camaro does not start or nothing no sound at all. the guy cut a key for it.
RED_WING45
  • 33 POSTS
i have a key but no chip in it. can i get a used ingition and key from a junk yard and make it work.
MERLIN2021
  • 17,250 POSTS
It may be the wrong key, or it may be the wire for keysense broke in the column, but it sounds like an ignition/key problem, Do all lights and radio work? Or is the car dead? And have you checked the cable going to the starter? Some dont even have the chip. It can be the starer solenoid at the starter on GM. For an "engine not cranking" condition with A/T, determine if condition exists in both Park and Neutral positions. If condition occurs in one position and not other, a more probable cause is neutral start switch.
https://images.2carpros.com/forum/automotive_pictures/62217_NSS_1.jpg
RED_WING45
  • 33 POSTS
can i use another ingition from another 91 camaro
FREDDY12
I recently bought a 91 camaro, this car is a project car from top tp bottom....meaning it needs a lot of work. The motor had been replaced at one time or another and I need to put a new starter on. My question is: how to I find out what motor is in there? It is a 8 cyc. gm motor, that I know for sure, but is it a 5.0 or a 5.7 liter I don't know. I was going to take in the old starter but it didn't fit right to start with, it kept slipping on the fly wheel and it had about 1/2 inch of shims under the one side to make it fit that good. I need help on how to find out what year and size the motor is so I can get the right parts for it.
E40WATER12
  • 522 POSTS
If you look under near the drivers side of the engine block near the motor mount, There should be a # stamp stating the motor info 350 or 305, The both motors are the same for parts, Just cyl bore is bigger, Block length are the same.
MERLIN2021
  • 17,250 POSTS
Yes but you need to reassemble it without breaking the wire. But you should test for power at these other locations. If the VIN was given to the Dealer that made the key, they should have given him the right one. Neutral saftey, bad connections at starter, bad starter, or blown fuse can all do this to you! Checked all fuses? Even the ones under the hood? Checked for power at the wires on the starter when in crank?
RED_WING45
  • 33 POSTS
do you know the ohms for a 91 camaro was going to try to bypass the vat system
MERLIN2021
  • 17,250 POSTS
The original Key needs to be looked at for a resistor chip, then measured...Call Chevy dealer with your VIN and see if the can look it up "as built" Then you'll know for sure. Behind the right side of the dash is the passenger key decoder module. If it has one, then your car should have a chip on the key.
https://images.2carpros.com/forum/automotive_pictures/62217_cam_1.jpg
RED_WING45
  • 33 POSTS
i dont have the original key for my 91 camaro. dealers want alot of money to help.
RED_WING45
  • 33 POSTS
what video are you talking about ty john
CHRIS BAKER2
I have a the RS model that will not do anything when you turn the key to start it. New starter, good battery, new alternator, new neutral safety switch. It will not click or nothing. What could it be?
MERLIN2021
  • 17,250 POSTS
THE MOST IMPORTANT thing you can do, is go to Chevy dealer with the Vehicle Identification Number, it's on the dash behind the left side of the windshield, have them make a key with your V.I.N. this will ensure you have a key that should work, until then, we cant measure the resistance on the key, or start the car.
HMAC300
  • 48,601 POSTS
it goes through these things prior to going to starter, you may have one that has a security module that I did not mark as most did not check the relay. it may be in the inconvenient center on left hand side of steering column. See picture.
RED_WING45
  • 33 POSTS
do you have to remove the plug to test the resisters so it will start. there is a plug like there i tryed it and no luck with the plug there is two wires passed the plug there are purple and white is that the ones it a 91 camaro ty john.
HARRY P
  • 2,292 POSTS
If your key has a chip on it, then you have the security module. Take your key to the dealer and have it checked. They will probably do it for free or pretty cheap. Let us know.
MERLIN2021
  • 17,250 POSTS
Check your email for testing everything reated to the security system. Special interrogator tool needed to test for the correct resistance, or VIN taken to Chevy.
RSCAMERO
car runs well but sometimes it wont even turn over when i turn the key starts right up when it wants to would you have suggestions what to look at . replaced battery and starter alternator is good would it be in the ingnition switch or a fuse
JDL
  • 16,098 POSTS
Welcome to the forum. I'd check the circuits at the starter solenoid. The wiring to the S terminal is usually a purple wire, goes hot with the key in the crank position. If it isn't hot, possibilities, ignition switch, feed to or from--- neutral switch, when it acts-up did you try cranking in neutral,-- wiring circuit. If everything is hot and all cables in good shape, I'd have to check the starter.
MARVELBOI28
hello yes got in car the other day went to start it but nothing just a noise like clic clic clic rrrrrr engine didn't rotate then nothing dead power dash light and all went out try to start it again same thing so got new battery and it's doing same thing, so i would think it may be the starter? thanks guys Joel
TEAG
  • 158 POSTS
Your battery is close to dead if not there yet. Try jumping it or putting it on a charger. Also check and clean the battery posts. A bad connection could restrict the flow of current. If none of that works.....replace the battery.
Check this guide out
MARVELBOI28
i did do all of that, and it still does the same thing with new battary just click click click like before so??
Apr 7, 2020 at 12:00 PM (Merged)
TEAG
  • 158 POSTS
Ok......Try following the battery cables and make sure theyre all clean and have good connections. If they all look good and are tight.....you might want to have your starter checked. If you take out your starter you can check it yourself by hooking it up to the battery and see if it engages. Dont hold the power from the battery on the starter too long or youll burn it out. If the starter is good.....it should spin and pop out a little. Also check all your fuses and make sure none are blown. That clicking noise is usually a sign of insufficient power supply though. So really check the battery cables........both ends. Then either get the starter checked or check it yourself. I believe some auto parts stores do free starter tests. Let me know what happens and we'll go from there.
MGCAMARORS
  • 9 POSTS
it sounds like bad alteernator or check fuse box for ecm fuse hit me back if worked
