1997 Chevrolet Blazer Repair Question
Topics covered: Window.
Asked on May 26, 2007
Manually pull up a bad power window on 97 blazer???
My driver's side window stopped working on my 97 Blazer. It's stuck in the down position. I know i probably need a new motor or regulator, but I was wondering if there's anyway i can manually pull the window up instead of leaving it down for the time being. Any info would be greatly appreciated!!
Answer
Replied on November 2, 2007
I had same thing, I used to pull up at the same time as I hit the button, usally it would take a few times between the circuit breaker blowing to get the window up.
If the breaker keeps blowing then you have no choice but to replace the motor. You cannot pull the window up with the motor in place and not running.
