2001 Chevy Blazer Door Hinge
2001 CHEVROLET BLAZER
170,000 MILES • 6 CYL • 4WD • AUTOMATIC
PRICH67
My Blazer has lost the spring and roller assembly on the top hinge (attached to the vehicle) of my drivers side door. The upper hinge (the one attached to the door)has cracked near the pin and the door is now sagging about 1/2 inch and will not close properly. The hinges looked welded on, not bolted. Do I need to replace the whole door to fix this? Can the hinges be replaced? Any solutions?
Nov 30, 2008 at 5:52 PM
