The 4wd won't engage. Had new 4wd atuo switch put on, the actuator ok. I can tap on the tccm and it will work sometimes. At random it might start working at anytime. anyone have a clue. the dealership and the trans shop couldn't figure it out. if i pull the 4wd drive fuse under the hood when it is in regular mode will it cause any problems?
thanks
thanks
Oct 24, 2010 at 8:13 AM
