1996 Chevy Beretta draining battery
1996 CHEVROLET BERETTA
163,000 MILES • 6 CYL • FWD • AUTOMATIC
ROCKPOSER16
my battery is being drained intermitently there is a constant power draw on it without the key in ignition or anything on with doors closed. im thinking a passive belt system solenoid is being activated by either a bad relay or a sensor controlling it. i have recently repaired the drivers side window back on the window track and noticed the solenoid was extremely hot.i've also pulled the NO. 11 (15 amp) fuse which controls the courtesy lamps,clock,abs,radio/cd,audible warning system, passive belts. has anyone had a problem with a sensor in the passive belt system sensor switch if there is one and or relay that controls that solenoid inside the door on the seatbelt roller mechanism or is there something else stuck on or active, also there are no lights on in the dark?
Aug 17, 2009 at 10:29 PM
