ignition firing order diagram
2007 CHEVROLET AVEO
BLACKHAT
It is a 2007 Chevrolet aveo 1.6, 16 valve e-tech 2 I was changing the spark plugs and i got the ignition wires in the wrong order when i put them back. I need the ignition firing order and disturber order. Please
Oct 19, 2013 at 5:51 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,354 POSTS
Here is the firing order.
Firing Order .................... 1-3-4-2
When looking at the front of the vehicle. Cylinder 1 is all the way to the left (passenger side) then it progressives towards driver side. Hope this helps. Check out the diagrams (Below)
Dec 24, 2017 at 3:09 PM
KEVINDUANE
what is correct firring order
Mar 25, 2019 at 11:43 AM (Merged)
FACTORYJACK
  • 4,159 POSTS
I showed several engine options in GM service info, 1.2l, 1.4l DOHC, 1.4l SOHC, 1.5l, and a 1.6l. They all show the firing order to be 1-3-4-2.
ANGELTAMI
I need the firing order for my car
Here is the engine ignition firing order
Firing Order 1-3-4-2
Check out the diagrams (Below) Please let us know what happens.
