The van is backfiring I was wondering if I have a crossed plug wire. I replaced the plugs and wires also. Thanks For the help
Jun 20, 2008 at 9:14 PM
CAR REPAIR CONTRIBUTOR
Yes, this can be the problem, here I have included some firing order diagrams so you can double check.
Please let me know if you need anything else.
Best, Ken
Jan 17, 2017 at 12:46 PM
JSNAPZ1212
MEMBER
1 POST
what is the Firing order for 1995 chevy astro 4.3L
Jun 29, 2020 at 11:33 AM
(Merged)
SERVICE WRITER
1-6-5-4-3-2
(Merged)
LEILANI67
MEMBER
DONT HAVE THE TROUBLESHOOTING SECTION IN MY MANUAL. COULD I PLEASE HAVE THE FIRING ORDER OF SPARK PLUGS FOR CHEVY ASTRO.THANK YOU!
(Merged)
JDL
What is the litre size of engine?
(Merged)
JDL
This info is for the 4.3L engine.
Image (Click to enlarge)
(Merged)
WESLEY_MYS
MEMBER
my distributor is 380 out. best way to reset it
(Merged)
Do you have a repair manual if so-Put the engine no.1 piston on its compression stroke/TDC, align the cam and crank sprockets to their markings, put crank pulley on TDC/0 deg and rotor pointing to no.1 cap tower.
(Merged)
GENTECHIT
MEMBER
When the plug wires are coming from the distributor cap to the Spark Plugs, Which wire goes to which plug?
(Merged)
Here is a picture of what you need.
Let me know if it helps.
(Merged)
ANDYS
MEMBER
the order on a distrubeter cap. 1992 astro cahevy 2 w/d
(Merged)
DOCFIXIT
this help
(Merged)
ANDYS
MEMBER
the cap does not have any numbers so i dont know which is one
(Merged)
ANDYS
MEMBER
it turns on but i feel like i have to put more force on the gas. it feels more heavy to ride
(Merged)
DOCFIXIT
How many miles on plugs,filters wires cap ect. has fuel pressure been checked. Check engine light on? this sudden or came on over time?
(Merged)
ERNIE SWAN
MEMBER
1 POST
I was hoping to find out the wiring order of the spark plug wires at the Distributor cap?
Jun 29, 2020 at 11:34 AM
(Merged)
OBXAUTOMEDIC
Here is the firing order....
(Merged)
ERIKATVEGAS
MEMBER
1 POST
what is the firing order on the distributor cap?
(Merged)
Specifications
FIRING ORDER
(Merged)
