I was removing the thermostat housing bolts to change thermostat and didnt realize the wire attached under front housing bolt was twisting. Anyway with it being 12 degrees outside it didnt take much and it snapped off. My question is what does this wire do? Is it a ground? Something quite important or what? Is there an easy fix for this without rewiring that cluster. Can I just tuck the wire under the bolt when I fasten it back down? Thanks in advance for any help!
Dec 31, 2009 at 6:08 PM
