Removed rear seat and do not see any fuses or relays for rear brakes
Sunday, November 21st, 2010 AT 2:39 AM
MECHANIC
What is your exact problem?
Mark (mhpautos)
SPONSORED LINKS
Sunday, November 21st, 2010 AT 3:15 AM
RASTA2BAD
MEMBER
Center brake light on, tail light bakes stopped working
Sunday, November 21st, 2010 AT 3:29 AM
MECHANIC
The indicated wire is the one you want, I am not familiar with this model but the pic has come from Mitchell 1 data base.
Mark (mhpautos)
Image (Click to make bigger)
Sunday, November 21st, 2010 AT 3:40 AM
FACTORYJACK
MECHANIC
Have you checked and replaced the stop/tail bulbs?
Monday, November 22nd, 2010 AT 12:03 AM
BOBOU812
MEMBER
Under backseat. Right side of vechicle. Pull the carpet forward. Only a inch or two. It's a couple inches long bout inch wide should be black. Might have a Christmas tree holding carpet in place.
SPONSORED LINKS
Wednesday, November 13th, 2019 AT 4:01 PM
KEN L
MASTER CERTIFIED MECHANIC
Please feel free to use 2CarPros anytime!
Saturday, November 16th, 2019 AT 1:20 PM
GDIEHR
MEMBER
1 POST
2004 CADILLAC CTS
6 CYL
2WD
AUTOMATIC
120,000 MILES
The left and right brake lights do not work; bulbs are fine. Center-mounted brake light works.
I suspect a fuse but using fuse diagram and coverage cannot find anything that identifies the outboard brake lights fuse.
Saturday, November 16th, 2019 AT 1:21 PM
(Merged)
MECHANIC
Hi gdiehr, Welcome to 2carpros and TY for the donation
The fuse for the brakes is good otherwise the high mount lite will not come on.
Inspect and test the joint connector located below left rear on left rear fuse block
(Merged)
MWRIGHT100783
MEMBER
1 POST
2003 CADILLAC CTS
6 CYL
AWD
AUTOMATIC
127,500 MILES
WHAT KEEPS CAUSING THE BRAKE LIGHT FUSE TO KEEP BLOWING?
(Merged)
BLUELIGHTNIN6
MECHANIC
Must be a short in the brake lamp circuitry. Check wire harnesses at brake lamp assemblies, ensure no wires are damaged or loose. If OK, check the brake lamp switch under driver dash, on brake pedal arm.
(Merged)
BOBOU812
MEMBER
I just fixed mine. Had no brake lights. Had tail lights. Didn't have speedometer either. Mouse chewed through 3 wires under hood. Removed battery 3 wires going to plug in kinda tucked inside passenger side fender. Odd how those 3 control brake lights and speedometer.
Saturday, November 16th, 2019 AT 4:34 PM
KEN L
Nice work, we are here to help, please use 2CarPros anytime.
