1998 Cadillac Catera
Engine Cooling problem
1998 Cadillac Catera 6 cyl Two Wheel Drive Automatic 76000 miles
A problem that most 98 caddi has is that the oil cooler always leaks and causes the oil and water to mix, I solved the problem by removing the oil cooler and running a new line out side. Now the oil pressure is high and goes up and down when you drive. The one reason I think is because the line is smaller. I would like to know if changing the size of the original line could be the problem or even the lenght of the line?
August 16, 2010.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
