Mechanics
SIGNAL FLASHERS
1993 Buick Regal
1993 Buick Regal
where do I find the flashers on this modal
Woofy
February 5, 2010.
On the passenger side there is a component center, and the flasher is on spot 10, behind the glove box...
http://www.2carpros.com/forum/automotive_pictures/62217_Flasher_2.jpg
Merlin2021
Feb 5, 2010.
So I would need to remove the glove box to get the this flasher
Woofy
Feb 5, 2010.
YOU COULD TRY OPENING IT AND EMpTY it out, then on the side, push the tab in and it should tilt all the way out, then just reach in and change it.
Merlin2021
Feb 5, 2010.
1193 buick regal signal flashers well I hazards are on the passagers side under the dash so where are the onther ones there seems to be two?
Woofy
Feb 7, 2010.
Check back Monday, I will take another look, You need which one? Emergency flasher, or turn signal flasher?
AD
Merlin2021
Feb 7, 2010.
AD
