Oil pressure warning light
MYQWON
  • BUICK PARK AVENUE
I have a 97 park ave with 117k miles last week my oil pressure light started to blink followed by a warning bell sound, so I went ahead and got an oil change, but that didn't work. Now sometimes the oil light stays on and my oil pressure drop from 129psi to 0 psi than return normal and it like a repeat, have any ideas on what it could be?
Tuesday, November 20th, 2007 AT 4:53 PM
  • 31,937 POSTS
Hi there,
The first thing to do is to have the oil pressure tested with a master gauge, this is a calibrated gauge that will be screwed into the oil pressure sender port. This will give a true indication as to what the oil pressure is doing if that's okay replace the oil pressure sender. Here is the location. Check out the diagrams (Below). Please let us know what happens. If it not okay the oil pump will need to be replaced
Cheers, Mark (mhpautos)
Tuesday, November 20th, 2007 AT 8:37 PM
SEASTAR3
  • 1998 BUICK PARK AVENUE
Recent mechanical work entailed taking off oil pan to check for a small leak on our garage floor. Following repair allegedly having to do with oil sending unit, while highway driving the alarm went off and soon after the oil light came on. We knew the oil and filter had just been done, but checked oil level and found it "full."
Mechanic rechecked car and told us he had adjusted the oil pressure and thought previously it had been "turned down too lean" following repair. He added that he had replaced the oil sensor, and did not charge us for these adjustments.
Driving about three, four miles from his shop the alarm went off again, with the oil light coming on - primarily when slowing for a stoplight/sign and pressing the gas to gain speed from the complete stop. Also, the alarm bonged and light came on if you did a highway curve or right/left turn. The mechanic is not our usual GM dealership, who has gotten too expensive for us to afford easily.
The engine light has been re-coded probably six times and does not stay off long. Local Cadillac/Buick dealership thought maybe a fuel line air hole, but a smoke test did not prove that to be true. A new GM gas tank cover did not cure the problem either.
We love this car and did not want to get rid of it. We take very good care of it and it is garaged most of the time at home. If you can tell us how to pamper and repair her, we will be most grateful.
Friday, August 31st, 2018 AT 6:53 PM (Merged)
Mechanic rechecked car and told us he had adjusted the oil pressure and thought previously it had been "turned down too lean" following repair. He added that he had replaced the oil sensor, and didn't charge us for these adjustments.
My question for above is how did he adjust the oil pressure- The oil pressure relief valve maintains/controls the oil pressure. There is no such animal on adjusting oil pressure-baloney stuff
Have them hook up a mechanical oil pressure gauge to determine the actual oil pressure.-Could be the oil pressure sending unit is failing but it was changed. And it could very be the gauge is out of calibration or wiring problem
Your probable causes could be an oil pump/engine bearings/clogged up return lines etc.
MBAIL70
  • 6 CYL
  • FWD
  • 128,000 MILES
My change oil light came on, so I changed my oil. The light is still on how do I reset the switch to make light go out
  • 108,300 POSTS
Turn the key to the run position (do not start the engine) and pump the gas pedal to the floor three times. Wait for the light to flash or a ding. Then you can shut the key and it should be reset.
Let me know if this works for you. If it doesn't, then it will need to be done through the radio. A little more difficult, but I believe in 1998, what I discussed above is how it is done.
VMAN9000
  • 6 CYL
  • FWD
  • 180,000 MILES
What causes your oil pressure to go up and down causing the oil light to come on
BLUELIGHTNIN6
  • 16,542 POSTS
First ensure oil level is full. Faulty oil sending unit o a weak / failing oil pump may cause this issue. Best thing to do is test the oil pressure with a mechanical oil pressure gauge so you will be certain it is actually fluctuating. If it is, suspect faulty oil pump. If it is not then suspect faulty sending unit.
HTGNWV
  • 6 CYL
  • 103,000 MILES
98 Buick Park Avenue. Oil pressure light came on, I topped off the oil, the pressure goes up and down when it is driving
Check the oil pressure with a mechanical gauge, if normal replace the oil pressure switch. If abnormal could mean oil pump and/or engine bearing.
