Mechanics
78 W/ OLDS 403 STALLING?!
1978 Buick Electra
Engine Mechanical problem
1978 Buick Electra
When I first start the car and drive for 20 minutes or so. Every thing is fine. But as it gets warmed up or after the 1st 20 minutes it acts as if it's running out of fuel. It's doesn't matter what gear I'm in. It doesn't matter if I let off. After 20-30 minutes is stalls and then. Then it won't even turn over. When u turn the key it acts like it doesn't have any juice? However. All the dash lights & head lights (all electrical) is fine.
After letting it sit for another 20 minutes (cooling off?) It will turn over, start, and run fine. For 20 more minutes. Then we do it all over again.
Herbysgal
September 20, 2010.
Test the coil, distributor pick-up coil and the ignition control module
Rasmataz
Sep 20, 2010.
AD
