Thermostat replacement replacement instructions please?
ANONYMOUS
  • 2003 BUICK CENTURY
  • 150,000 MILES
How to replace the thermostat in the 3100 V-6 engine?
Saturday, December 15th, 2012 AT 7:33 PM
FREEMBA
  • 1,152 POSTS
Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
This video shows the job being done on a similar car but the process is the same.
https://youtu.be/jhXBAtcutQo
Tuesday, April 16th, 2019 AT 6:53 PM
  • 52,797 POSTS
I find it much easier to remove the throttle body. When you do this, it is much easier to get to the housing bolts
CJM6082
  • 2002 BUICK CENTURY
Where can I find some Diagrams of a 2002 Buick Century Custom (V-6 Automatic) to help me switch the Thermostat out?
Wednesday, May 26th, 2021 AT 12:22 PM (Merged)
ZACKMAN
  • 4,202 POSTS
Here is a guide that will show you what you are in for when doing the job.
There are diagrams to show you wehat it like on your car there is more (below)
https://www.2carpros.com/forum/automotive_pictures/55316_02centurytherm_1.jpg
View from the other side
https://www.2carpros.com/forum/automotive_pictures/55316_02centurytherm_2.jpg
Check out the diagrams (Below)
Cheers
HOUSEOHUFF
  • 6 CYL
  • 97,997 MILES
Where is the thermostat on a 2002 buick century
  • 108,328 POSTS
Follow the upper radiator hose to the engine. It will lead you to the thermostat housing. Remove the housing and the T-stat is there. NOTE: Before doing the work, disconnect the battery and drain the coolant.
Here is a picture of it
BACK YARD MECHANIC2
  • 6 CYL
  • 97,000 MILES
I own a well-maintained 2003 Buick Century. Recently, the low coolant light came on. Flluid levels revealed no proplems. I then had my oil changed and the light came on intermittantly, but no signs of overheating, fluid leaks, etc. Last night the engine temp light came on. Guage was nearly pegged, but not completely. I revved up the engine and the engine immediately returned to normal temp, but the heater blew cool air. Could this be a thermostat problem, and if so, where is it located. I can't find it on top of the radiator or at the base of the water pump.
SERVICE WRITER
  • 9,123 POSTS
I'd start with a stat.
The low coolant light is more likely a bad sensor level problem.
https://www.2carpros.com/forum/automotive_pictures/30961_1a_1.jpg
https://www.2carpros.com/forum/automotive_pictures/30961_1b_1.jpg
https://www.2carpros.com/forum/automotive_pictures/30961_1c_1.jpg
SHELBYGT08
  • 11 POSTS
  • 2001 BUICK CENTURY
  • 3.1L
  • 6 CYL
  • 41,000 MILES
I Bought an AC Delco thermostat for my car. The factory thermostat appears to have a built-in factory o-ring that’s actually part of the thermostat. If I am correct I should not need a paper gasket or any sealant when I install this thermostat correct? Thanks
Are you talking about the rubber o-ring around the thermostat itself (pictured) or are you talking about the seal for the housing itself?
Either way, if it has a rubber o-ring then you do not need another gasket.
SHERRY CARPENTER
  • 1999 BUICK CENTURY
  • 20,000 MILES
How to replace thermostat 3100 engine
HMAC300
  • 48,601 POSTS
See pics then pretty much reverse removal follow cooing system bleeding procedure after install
NICOLE09_2003
  • 1998 BUICK CENTURY
  • 6 CYL
  • AWD
  • 16,000 MILES
I need to know where to find the thermostat and how to replace it?
Here is a guide to help you see what you are in for when doing the job and the diagrams below will show you the location:
Check out the diagrams (below). Please let us know what happens. Cheers
TJDPSR
  • 1994 BUICK CENTURY
  • 6 CYL
  • FWD
  • 166,693 MILES
I have locate where the thermostat goes, but I have noticed it is not in a very friendly place to get to, is there a trick or special way to get to this thermostat without knocking the hide off of your knuckles? Also, is there supposed to be a gasket with the new thermostat or is it the rubber gasket attached to it the only one?
Thanks in advance.
Tracy
Wednesday, May 26th, 2021 AT 12:23 PM (Merged)
JALOPYPAPA
  • 467 POSTS
Hard indeed to get to without removing the throttle body (it needed a good cleaning, anyway, right?). The throttle body will need a new gasket and sealant for the coolant connection. The thermostat needs only the rubber edge seal, I think. Be sure to place it right side up.
JORE8888
  • 1993 BUICK CENTURY
  • 6 CYL
  • FWD
  • 120,000 MILES
How do you remove a thermostat from a 1993 Buick Century 3.3 Do I need to remove the throttle body?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,110 POSTS
Here is more information BELOW
Disconnect battery negative cable.
If necessary, remove air cleaner assembly.
With engine cool, drain engine coolant below thermostat level. Never open cooling system with engine hot.
Disconnect radiator hose from thermostat housing.
Remove thermostat housing retaining bolts, then the housing, gasket and thermostat.
Check out the diagrams (Below) both 4 and 6 cylinder engines.
Cheers, Ken
SHURLA
  • 1992 BUICK CENTURY
  • 6 CYL
  • FWD
  • 100,000 MILES
Location of thermostat 3300
BMRFIXIT
  • 19,053 POSTS
Refer to Fig. 16 when performing the following procedure.
1. Disconnect battery negative cable.
2. If necessary, remove air cleaner assembly.
3. With engine cool, drain engine coolant below thermostat level. Never open cooling system with engine hot.
4. Disconnect radiator hose from thermostat housing.
5. Remove thermostat housing retaining bolts, then the housing, gasket and thermostat.
6. Reverse procedure to install noting the following:
a. Ensure thermostat gasket area is thoroughly clean.
B. Install thermostat with new gasket.
C. Apply a suitable sealer to thermostat housing retaining bolts. Install and torque bolts to 20 ft. Lbs.
D. Refill and bleed cooling system as necessary.
See the diagram below
