2005 Bmw X3 Location Reverse Light Switch
2005 BMW X3
100,000 MILES
ANONYMOUS
location of reverse light switch
Mar 4, 2013 at 9:39 PM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
Greetings
Your vehicle's reverse light switch is located on the right rear side of the transmission.
Mar 4, 2013 at 9:40 PM
ROSSBRO
Electrical problem
2005 BMW X3 Four Wheel Drive Manual
Hi all,
I have a 2005 2.0 diesel BMW x3 and the reversing (back up) light switch needs to be replaced.
I've not had the car that long so am unsure of where everything is situated on the car, but when I've gone underneath it, I can see that everything is covered by heat shields/protective casings.
Can anyone give me a clue as to which section the gearbox sits above so I don't end up stripping all the car to get to the switch and if there's any hints/tips you can give me for doing the job!
Thanks
Ross
Jul 13, 2019 at 3:20 PM (Merged)
DOCHAGERTY
  • 9,606 POSTS
The switch is on the transmission at about where the drivers butt hits the seat. This is an easy, straightforward job so don't be too concerned. I would definitely have an electric screw gun to get those shield screws off.
ROSSBRO
Thanks for your help with this.. managed to change the switch myself this afternoon and all is working correctly!
DOCHAGERTY
  • 9,606 POSTS
No worries!
