one month ago we put in a new radiator because the rad fluid kept leaking out. We actually did not see the damaged rad but were told that was the problem and paid for the repair. The smell of antifreeze was evident since the replacement, but it was thought that some was spilt and was buring off. It was never mentioned to the mechanic, but as a general comment by ower and passangers of the car.
Last night the housing surrounding the rad was being hit by the rad fan and we could see that the bottom and side brackets of the protective housing were not inserted as they should be. We drove it to the shop.
When the shop opened the hood it was apparent that in that 28km drive that the fan hit the housing and blew apart damaging the housing and new rad.
I was informed initially that the bearing was 'gone' from the rad fan and that it had to be replaced as well as the other parts:rad, fan, housing. Later i was informed that the waterpump was the actual culprit and i was shown the open pump where the metal was bend in one "arm?, lung?" and how it would not turn in one direction, but did move freely in the other direction. This too would have to be replaced.
Finally my question: Can the improperly attached fan housing cause the fan to do the damage to the water pump? or
Can the water pump be the cause of the damage?
Oct 21, 2008 at 12:31 PM
