1987 BMW 325 won't start / run
1987 BMW 325
WAILER
Engine Performance problem
1987 BMW 325 6 cyl Two Wheel Drive Manual 200K miles
there is no power arriving at the coil & the fuel pumps. The coil is new, the ecu is new, the ign switch is new, the relays check out, the fuses are good and direct power to the pump makes it work (no spark though). I downloaded a wiring diagram that shows an auxiliary fuse block, but can't find one? This no start/run/stall problem started last year intermitently, when I brought it out of storage this summer, it started twice and no more.
Help I'm going nuts over this!
Wailer, 325e Coupe.
Sep 10, 2008 at 8:16 AM
