Do below to determine whether it's a fuel or spark problem:
Cranks but no start condition:
Disconnect a spark plug wire or two and ground it to the engine have helper crank engine over, do you have a snapping blue spark? If so, you have a fuel related problem. check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors.
Mar 9, 2017 at 3:43 PM
(Merged)
