1993 Acura Legend Repair Question
Asked on April 4, 2010
1993 Acura Legend
Engine Cooling problem
1993 Acura Legend 6 cyl Two Wheel Drive Automatic
i have a 1993 acura legend..engine fans are not coming on, i checked all the fuses but still they dont come on..is there a relay to the fans im not aware of i also replaced the heat sensor valve
Answer
Replied on April 4, 2010
Hi smiiley101,
Is your vehicle a coupe or sedan and is it with automatic or manual AC system?
Does the fans come on when the AC is turned on and compressor engaged?
Have you tested the fan motors?
