Car cranks but will not start
1988 ACURA LEGEND
295,000 MILES
TWEED69
Car cranks but will not start after sitting for twelve months. I sprayed starting fluid into the air filter and it started for thirty seconds then cut off and would not start. I also opened the fuel filter bolt when I started but did not see any fuel come out. Is it the fuel pump and where is it located?
The car was running great before it sat for months. has a new battery.
Oct 17, 2013 at 8:54 PM
SATURNTECH9
  • CAR REPAIR CONTRIBUTOR
  • 30,869 POSTS
Was the engine cranking when you saw no fuel coming from the fuel line when it was unhooked?
Oct 18, 2013 at 11:25 AM
SATURNTECH9
  • 30,869 POSTS
The fuel pump should be in the tank before I would suspect a bad fuel pump you have to make sure you have power and ground to the pump.
Oct 18, 2013 at 11:28 AM
HONDATECH1983
  • 109 POSTS
You need to listen for the main relay clicks. You should hear a click from under the dash when the key is turned on and another click about two seconds later. If you do not hear the clicks you should look into replacing the main fuel relay.
Mar 5, 2014 at 11:34 AM
LKINDER
six cylinder front wheel drive automatic 219,019 miles
gets fuel, has spark, and no visible stoppage of air. Battery charging and starter clicks.
Mar 6, 2017 at 2:22 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi LKinder,
Was any repairs done prior to this occurring?
What is the fuel pressure at the fuel rails?
Did you try using starter fluids?
C BUDDY
Front wheel drive manual
my car will not start but it will turn over and my clutch stays on the floor.
what causes these problems?
KHLOW2008
  • 41,814 POSTS
Hi C Buddy,
Engine will not start could be due to lack of ignition sparks, fuel pressure or supply and mechanical problems.
Check out this link for procedures on testing.
https://www.2carpros.com/kpages/first_things.htm
The clutch staying on the floor should be due to hydraulic system failure.
Check the fluid level in clutch master cylinder reservoir. If level is good, you could have a bad master cylinder. You would need to lift the pedal and pump it a few times to get any pressure.
ANONYMOUS
  • 0 POST
My car will turn over when I try to start it, but it will not start. I tried to get it jumped and had no luck.
  • 110,190 POSTS
If it is turning over, then your battery sounds good. Check to see if there is spark and fuel to the engine?
