1995 Acura Integra Repair Question
Topics covered: Abs, Accumulator, Brakes.
Asked on March 28, 2010
Weird buzzing sound then abs light, then
Brakes problem
1995 Acura Integra 4 cyl Two Wheel Drive Automatic 158000 miles
When I turn my car on, there will be a series of weird buzzes from the passenger side, under the hood. After that happens eventually my ABS light will come on and My ABS wont work anymore. What are the possible problems and how would you fix them? Thanks a lot!!!
- Buddy
- Buddy
Answer
Replied on March 29, 2010
Hi Buddy,
Symptoms indicates a bad ABS accumulator which is leaking internally. The buzzing is the motor working to pump up the pressure but when pressure does not build up after a certain time lapse, the ABS control unit cuts of the ABS system
You would need to replace the accumulator and bleed the brake system
