2CarPros - Car Questions & Answers
2001 Acura CL Repair Question
Topics covered: Spark, Engine, Coil pack.
Asked on September 25, 2010
2001 Acura CL Car won't start when hot
2001 Acura CL 6 cyl Two Wheel Drive Automatic 115000 miles
My son's 2001 Acura wil not start when it is hot, >95 degrees. Once it cools down a little is will always start
Avatar Asked by caspba
Answer
Replied on September 25, 2010
When its hot and it refuses to start try to catch it if its fuel or spark problem-Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Tiny Answered by rasmataz
68 questions asked
