1998 Acura CL Repair Question
Asked on August 1, 2010
1998 Acura CL Car wont start
Engine Mechanical problem
1998 Acura CL 6 cyl Front Wheel Drive Automatic 155000 miles
Try to start my acura and it wouldnt make a sound, battery is good and had the starter checked and it is good. What could it be? Heard it might be a relay if so where would this be located and how could i check it . thanks
Answer
Replied on August 1, 2010
You need a repair manual to track this problem down its not easy-start at the starter relay, transmission range switch and ignition switch
