2005 Chrysler Town and Country DOOR LOCKS
VMDUPH49
  • 2005 CHRYSLER TOWN AND COUNTRY
  • 6 CYL
  • FWD
  • 73,000 MILES
MY POWER DOOR LOCKS DIED. I PULLED OUT THE IOD FUSE AND PUT IT BACK IN. IT MAKES THE LOCKS WORK FOR A SHORT TIME, THEN THE DIE AGAIN. WHAT IS THE NEXT STEP?
Monday, August 2nd, 2010 AT 8:24 AM
  • 108,366 POSTS
Try disconnecting the battery for about 20 minutes. If that doesn't help, I believe there is a TSB out regarding the problem. What happens is this. The BCM power locks failure detection maythinks a lock is frozen. Thus, it would overload the system and burn out the solenoid. If disconnecting the battery doesn't help, chances are the computer will need reflashed (a dealer issue).
Let me know if it works. Also, since the iod holds power, make sure the clock on the radio says 12:00 when you reconnect everything. That way you are sure it has reset.
Let me know what you find.
Sunday, August 8th, 2010 AT 12:50 AM
VMDUPH49
I TOOK THE CAR BACK TO THE DEALER 5 DAYS AGO AND THEY REPROGRAMMED BODY CONTROL NODULE. SO FAR THEY ARE STILL WORKING.
Wednesday, August 11th, 2010 AT 5:23 PM
  • 108,366 POSTS
That is good to hear. Let me know if things change or if you have other questions.
Thanks for using 2carpros. Com.
Wednesday, August 11th, 2010 AT 10:49 PM
