HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mazda
626
Fuel System
Fuel Pump
Relay
Location
2000 Mazda 626 FUEL PUMP RELAY LOCATION
TPRINCESS05
MEMBER
2000 MAZDA 626
6 CYL
4WD
AUTOMATIC
85,000 MILES
Does anyone know where the fuel pump relay is located in my car or where the fuel fuse is located?
Sunday, February 22nd, 2009 AT 10:55 AM
MERLIN2021
MECHANIC
In the main fuse block under the hood behind the battery.
Sunday, February 22nd, 2009 AT 11:05 AM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Relay Location Content
I Donated And Asked Question, But Answer Left Out Full...
It Seems To Be Fuel Related. I Can Hear What I Believe To Be Fuel Pump When I Turn The Key On, It Hums For Aprox. 2 Seconds. Does That...
Asked by
JAMESV
1998
MAZDA 626
Fuel Pump Relay
Ny 98 626 4cyl. Is Having Problems Starting. The Haynes Manual Says Check (jump Pins) On The Fuel Pump Relay. I Can Not Find This In The...
Asked by
bdes64
MAZDA 626
2000 Mazda 626 How Long Should A Fuel Pump Last?
2000 Mazda 626 6 Cyl Automatic 142, 00 Miles In September 2007 The Fuel Pump Was Replaced On My 2000 Mazda 626. Since Then I've Only...
Asked by
Rhonni
1 ANSWER
2000
MAZDA 626
1990 Mazda 626 Replace Feul Pump
Replaced Feul Pump Getting Gas To Engine But It Will Not Stay Running Will Crank Then Die. It Is Like It Is Not Getting Gas.
Asked by
tnj1982
1990
MAZDA 626
2002 Mazda 626 Fuel Pump Removal And Installation
Engine Problem 2002 Mazda 626 4 Cyl Wheel Drive Type Unknown Automatic 12800 Miles How Do I Remove And Install A Fuel Pump And Filter...
Asked by
Briana Reynolds
1 ANSWER
2002
MAZDA 626
VIEW MORE
How to Use a Test Light
Fuel Pump Replacement
How to fix an engine that wont start
