1997 Chrysler Sebring oil pressure light
GJFULTON
  • 1997 CHRYSLER SEBRING
  • 6 CYL
  • FWD
  • 138,000 MILES
I am trying to figure out likely causes as to why when my cars rpm's drop below 1000 the oil pressure warning light illuminates.
Monday, December 8th, 2008 AT 10:15 PM
  • 31,937 POSTS
Hi there,
You should first get the oil pressure tested with a mechanical gauge, hot and at idle this will give you a true indication as to the oil pressure, if it is OK, the electric sender is faulty, if it is low, you will have a mechanical problem to check out, do the test first.
Mark (mhpautos)
Monday, December 8th, 2008 AT 10:53 PM
