Auto Repair Talk - Ask a Question, Get a FREE Answer.
Go Back
1994 Ford Ranger SOLENOID PROBLEM
Welcome to our question and answer forum where over 6,000
free auto repair questions are answered every month,
after you have completed our free signup you will able
to ask a question and receive an answer from one of our
many forum members.
If you elect to donate any small amount of money we will
assign one of our 2CarPros Certified Repair
Technicians to answer your question. Questions
with donations are answered promptly and 100% of the
donation is awarded to the technician helping you.
Watch our new
Car Repair Video Series
with Ken Lavacot.
Posted at Sat Jul 05, 2008 3:57 pm |
By
bigcat6460,
Likes cars! |
Give Feedback | Votes: 0 |
Engine Mechanical problem
1994 Ford Ranger 4 cyl Two Wheel Drive Manual 222000 miles
I have 1994 Ford Ranger XLT and it would not start and so I put a new Battery and Solenoid and now my truck won't start. When I hooked my battery terminals back up correctly, the small grond wire from the positive terminal started smoking and now the small ground is crinkled all the way to the starter. What could the problem be now? Any help is greatly appreciated.
| Find
diagnostic tools,
replacement parts
or locate a
car repair manual for your Ford Ranger Repair Question. |
Posted at Sat Jul 05, 2008 5:22 pm |
By
bigcat6460,
Likes cars! |
What I was meaning to say that where the main positive battery cable is connected to the battery terminal, there is a smaller red cable with it that was together and that is the way it was when I bought the truck. It is the original positive cable to the terminal and all I had to do was put on a new terminal because it would not tighten down but there is two red on the positive side and two black on the negative side of the battery. That was the way it came, I hope I am explaining without confusing anyone. Sorry if I did. I hope this helps and THANK you so much for replying.
| Find
diagnostic tools,
replacement parts
or locate a
Posted at Sun Jul 06, 2008 9:05 am |
By
bigcat6460,
Likes cars! |
No it won't even crank. It's like there is absolutely no power anywhere. When you hook a test light to the solenoid, it will show power on one side and that is all you get. No headlights or anything else. I had it running and then it died and would not hit again. It will not even crank. Fuel pump and everything else was fine until the solenoid was changed and then we had to put on a new starter. It was running and then we turned off the engine and now it does nothing.
| Find
diagnostic tools,
replacement parts
or locate a
Posted at Mon Jul 07, 2008 9:03 pm |
By
bigcat6460,
Likes cars! |
I have checked all the fuseable links and today I put on another new starter, because we had the first new one checked and was told it was stuck and fried. I went back to the auto parts store and they replaced it with another one. Then we checked all wiring and found a ground that had melted all the way to the starter. We took it out and ran a new one and the truck started and ran so we took it for a test run and thought it was o.k. but when we heard a noise we new it was the starter again, and of course it was. We took it off and had it tested by a mechanic and he said that it had stuck too and it had to be another hot ground somewhere. I explained what had happened and he said it sounds like the starter is not shutting off after the truck starts, because after everything was connected right that the battery was showing no charging as the truck was running. We are stumped, 2 starters and 2 solenoids and new ground. I don't understand why it keeps destroying starters. Any opinions PLEASE.
| Find
diagnostic tools,
replacement parts
or locate a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
