Timing marks for a 2.3 engine
REVKEV316
  • 1993 FORD RANGER
  • 4 CYL
  • MANUAL
  • 100 MILES
What do the timing marks look like for my truck listed above it has the 2.3 liter engine. The timing belt has been removed and the crank has been turned slightly so I need to get it back in time. Also, not sure if the valves can be damaged if I turn the crank without the timing belt on. Any tips or procedures would help. Thanks.
Wednesday, January 12th, 2011 AT 3:38 AM
REVKEV316
  • 20 POSTS
I answered it myself with a little web browsing. The following picture answered my crank timing issue. Hope it helps someone else.
I also found this guide on this site, look toward the bottom
https://www.2carpros.com/diagrams/ford/ranger/1993
Please let us know what happens so it will help others.
Cheers
Wednesday, January 12th, 2011 AT 5:19 AM
REVKEV316
  • 20 POSTS
Here is another picture that may help. There is a second (diamond shaped) mark on the aux pulley that has to be lined up on some models. Maybe this picture will help.
Thursday, January 13th, 2011 AT 5:01 AM
JOSHUNT76
Does the oil pump sprocket need to be in time with the crankshaft and camshaft on a 92 2.3 engine?
Tuesday, December 27th, 2016 AT 7:34 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 55,302 POSTS
No it does not. This drive just runs the oil pump and there is no balance or timing problems.
Friday, December 30th, 2016 AT 4:58 PM
HELLOINTREPID
  • 1993 FORD RANGER
1993 Ford Ranger 4 cyl Two Wheel Drive
i need a diagram showing the timing marks on the ranger-it has a 2.3 liter
Wednesday, November 11th, 2020 AT 6:30 PM (Merged)
MERLIN2021
  • 17,250 POSTS
Installation (Models With Distributor) 1. Install crankshaft sprocket (if removed) with recessed area toward crankshaft. See Fig. 1 . Install belt guide with flat side toward camshaft sprocket. Install camshaft sprocket with timing mark outward. 2. Install NEW camshaft sprocket bolt, and tighten to specification while holding camshaft with camshaft sprocket holder. See TORQUE SPECIFICATIONS . 3. Align camshaft sprocket timing mark with pointer. Properly position crankshaft so timing mark aligns with notch in front cover casting. See Fig. 2 . Remove the distributor cap, and ensure that the distributor rotor is facing the No. 1 position. 4. Install timing belt over crankshaft sprocket, then counterclockwise over auxiliary shaft and camshaft sprockets. Loosen belt tensioner bolt, allowing tension to be applied on timing belt. 5. Remove one spark plug from each cylinder. Rotate engine clockwise (viewed from front of engine) 2 complete revolutions. Tighten timing belt tensioner bolts to specification. See TORQUE SPECIFICATIONS . Ensure all timing marks align properly. See Fig. 1 . Install belt guide on crankshaft. 6. To install remaining components, reverse removal procedure. Tighten bolts to specification. See TORQUE SPECIFICATIONS . 7. Disconnect heater hose from fitting on thermostat housing to bleed air from cooling system when filling. Fill cooling system with Ford Coolant (E2FZ-19549-AA), or equivalent, until coolant flows from fitting. Install heater hose. Refill radiator. Adjust drive belts to proper tension. Fig. 2: Positioning Crankshaft Courtesy of FORD MOTOR CO. CAUTION: If camshaft sprocket was removed, install NEW camshaft sprocket bolt. DO NOT reuse bolt. NOTE: It may be necessary to push belt tensioner against timing belt, as spring tension may not move belt tensioner against timing belt.
https://www.2carpros.com/forum/automotive_pictures/62217_Rangera_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_Rangerb_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_rangerc_1.jpg
MCRUMP
  • 1993 FORD RANGER
  • 4 CYL
  • MANUAL
  • 243,000 MILES
What is the procedure for changing the timing belt on a 1993 ford ranger 2.3 liter engine. How do I align the cams and crank shaft for new belt install.
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_1941.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_423.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname2_625.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname3_245.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname4_123.jpg
NELSON PEREZ
  • 1993 FORD RANGER
Engine Mechanical problem
1993 Ford Ranger 4 cyl Two Wheel Drive Manual
I need to find out where the three marks go. (I need a picture of where marks go.) Thanks for the info, But I set the points on marks but engine won't turn over. (Any sugestions on what else I can do?)
DAVE H
  • 13,384 POSTS
https://www.2carpros.com/forum/automotive_pictures/266999_time_8.jpg
https://www.2carpros.com/forum/automotive_pictures/266999_time2_3.jpg
WHOFFMANN
  • 1993 FORD RANGER
  • 4 CYL
  • 57,000 MILES
What do I need to take off to get to the timing belt?
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_1123.jpg
