Hi:
Unfortunately, the clip's size isn't provided in the manuals. However, that should be easy to find.
The clip is called an E-Clip. If you go to any parts stores, they should have an assortment kit for under 10 dollars. I found a part number from Dorman if you want to check out what I'm referring to. The part number is, "Dorman 13325 E."
I attached a pic below. If you do go to a parts store, most have what is called a "Help Section" in the store that has a lot of Dorman replacement parts. That is where you would likely find these.
Let me know if this helps.
joe
See pic below
Image (Click to make bigger)
SPONSORED LINKS
Monday, May 20th, 2024 AT 7:10 PM
