Engine stalls at idle
PHYLLISJACQULINE
  • 2005 CHEVROLET MALIBU
  • 6 CYL
  • FWD
  • 60,000 MILES
When I crank my car it catches the stutters and dies. Can you tell me what may be wrong with it?
Thursday, July 15th, 2010 AT 12:53 PM
It sounds like you have a vacuum leak or the throttle body needs cleaning. Here are three guides to help us.
https://www.2carpros.com/articles/stall-at-idle
and
and
Friday, July 16th, 2010 AT 4:14 AM
DARIN_M66
  • 2003 CHEVROLET MALIBU
  • V12
  • FWD
  • 130,000 MILES
Car starts and runs fine except it will die if foot is removed from accelator. With control of the accelator, I can get the RPMs down to 600 RPM. There is no check engine light "on".
Saturday, May 23rd, 2020 AT 1:50 PM (Merged)
Inspect and test the idle air control valve and throttle position sensor, PCV and EGR valves-
Saturday, May 23rd, 2020 AT 1:51 PM (Merged)
DARIN_M66
It was the dirty throttle bore. Thanks
JENNIFER LYNCH
  • 2002 CHEVROLET MALIBU
  • 2.0L
  • 4 CYL
  • FWD
  • 230,000 MILES
Car turns over and starts, but it will not stay running.
JIS001
  • 3,408 POSTS
Clean the throttle body and idle air control valve. The valve is attached on the throttle body. If that does not work then replace the idle air control valve.
BULLETSPONGE62485
  • 1998 CHEVROLET MALIBU
  • 4 CYL
  • FWD
  • 125,000 MILES
When the vehicle is at idle it dies. We hooked the car up to a computer and produced no codes. Any suggestions as to what could be making it die? It starts right back up after it dies but will die a lot when it is at idle.
RHALL77
  • 3,361 POSTS
I there a security light blinking. Check and see if you are loosing fuel pressure or spark
BULLETSPONGE62485
No there are no lights blinking.
