Won't start
FKNBAD
  • 2001 JAGUAR XJR
  • 126,000 MILES
Drove fine, then light came on said (no abs/traction control available), then light came on (engine fail safe mode) the car would only idle, if excelerator was pushed nothing happened, once the car was turned off it will not restart.
Do you
have the same problem?
Tuesday, May 7th, 2013 AT 9:13 AM
HMAC300
  • EXPERT
Scan for codes and check fuel pressure first
Wednesday, May 8th, 2013 AT 8:40 AM
Recommended Guides
