Cranks but no start
TSHABALALA
  • 2021 DAEWOO NUBIRA
  • 1.6L
  • 4 CYL
  • MANUAL
  • 90,000 MILES
My car keeps cranking but does not start I removed the cam and crank sensors and replaced them now it still does then same. The cam looks like its fora Lenos and doesn't fit behind the timing head could it be that is the main issue uptill now
Do you
have the same problem?
Wednesday, February 12th, 2020 AT 12:28 PM
  • 52,797 POSTS
Much better thank you.
You need to check the compression to see if the timing belt has failed.
You need to test for spark at the plugs.
You also need to check for fuel pressure.
I attached flow charts to help determine the source of the failure.
Sunday, February 16th, 2020 AT 9:37 AM
BRIONEY WALKER
  • 2002 DAEWOO NUBIRA
  • 4 CYL
  • 188,501 MILES
It starts then but will not idle.
Thursday, January 21st, 2021 AT 4:37 PM (Merged)
  • 108,014 POSTS
There are many things that can cause this type of an issue. Do the simple things first. Check the air filter to make sure it or the induction tube are not plugged.
Check to make sure there are no engine vacuum leaks.
Check to make sure fuel pressure is within the manufacturer's specifications.
Here are the manufacturer's specs for pressure.
Fuel Pressure .................... 283-324 kPa (41-47 psi)
If the check engine light is on, check for trouble codes which can direct us to where the problem is coming from.
https://youtu.be/YV3TRZwer8k
Also, let me know if you are able to keep the engine running with your foot on the throttle or if it still continues to stall.
Let me know what you find.
TECA
  • 2001 DAEWOO NUBIRA
  • 4 CYL
  • 240,083 MILES
When I start my car it gives me a sound like lawn mower.
Thursday, January 21st, 2021 AT 4:38 PM (Merged)
If this is a constant noise like a lawn mower, more then likely you have an exhaust leak before the muffler. The muffler is meant to do just what is sounds like, it muffles the noise from the engine.
Just to confirm this can you get a recording of the noise so that we can hear it and that should give us the needed info.
We will be limited in the service information we can give you about your specific vehicle because we don't offer this vehicle in the USA so we don't have a manual. However, we can give general information because an engine is an engine and in this case, a noise is a noise no matter where the vehicle is in the world.
Thanks. We will wait to hear back.
TECA
I have added two videos. Hope it helps.
Oh. I am sorry. I didn't expect that so thanks for the videos. This is an engine knock.
I would suggest draining the oil and cut apart the oil filter and look for metal. However, I suspect you will find metal as this is bearing material and the noise you are hearing is metal on metal of the crankshaft bearings or rod bearings. Either way, I suspect you are going to need at least rebuild the engine or replace it depending on price of each.
Sorry for the bad news but that noise is not easily mistaken when you have heard it as many times as I have.
TECA
Thank you so much for clarifying my doubts. I think i'm in big trouble with the problem seen on my car. Once again appreciate your kind help.
I don't like being the bearer of bad news but I agree. Thanks for using 2CarPros. Please let us know if you have other questions. Thanks
NHLAIKS
  • 2000 DAEWOO NUBIRA
  • 200,000 MILES
My Daewoo Nubira cranks but will not start. I am not sure what the problem is, initially I thought it was the fuel but I filled it up and it started once but now it's not starting again.
Before it refused to start, the indicator lights stopped working on the dashboard and the lights as well then the car refused to start the following morning.
Please help.
Thursday, January 21st, 2021 AT 4:39 PM (Merged)
  • 52,797 POSTS
With no dash lights there is a connection issue or a possible failed pcm
NHLAIKS
All the dashlights come on. It was just the indicators. Now it starts but it accelerates and rev's immediately to 3 without touching the accelarater, I'm not sure what the problem is and as well the speedometer stopped working.
JOISHUA2625JR7
  • 7 POSTS
  • 1999 DAEWOO NUBIRA
  • 900,000 MILES
Hi my car wont start after all is been don, you gave me the firing order sequences a. Remove and install of head and replace gasket, torque sequences, but now try to start engine and it won't run, what else need to be done all the fuses are new battery.
Please Help :-)
KHLOW2008
  • 41,815 POSTS
You should have replied to your earlier post so that whoever attended to you can response when notification is received.
Did you check the engine compression?
Do you have sparks at the spark plugs?
Have you checked the fuel pressure and does starting fluids work?
JOISHUA2625JR7
  • 7 POSTS
Yes I did all that still I was told that the firing order is 1342 and how would I know in which position are they in the ignition coil? And how would I know is the timing is correct? I beleive if iwould get the correct answer I have ask my dad for some money to send to who ever help me out.
JOISHUA2625JR7
  • 7 POSTS
  • 90,000 MILES
A while ago I ask of you to give me the timing sequence and firing order of a 1999 daewoo nubira but what I didn't now is that this vehicle carries a 2001 engine, would this make a difference? And by the way still engine won't run or start?
KHLOW2008
  • 41,815 POSTS
You should continue with your previous post so that whoever attended to you can response when notification is received. This would keep the history of what had transpired in one thread for easier reference.
Yes, both engine are the same. Have you check the engine compression and are there sparks and fuel pressure?
