Blend door actuator
FT95
  • 2008 FORD RANGER
  • 3.0L
  • 6 CYL
  • 70,000 MILES
Trying to replace my blend door actuator.I can't get the new one to go in the hole. The D shaped piece is off by a couple of millimeters from the original part.I thought that might be the problem but I can't even get the old one back in.I removed the original actuator before I bought the new one. Is it possible the blend door changed position because there was nothing there to actually hold the door.
Thursday, September 17th, 2015 AT 6:03 AM
CAR-MAN145
  • 321 POSTS
Yes you just need to turn the motor till it goes into the door and then line up the screw holes. here is a guide to help you
Tuesday, September 22nd, 2015 AT 1:47 AM
RICK GAUVIN
  • 2007 FORD RANGER
  • 4.0L
  • V6
  • 4WD
  • 11,800 MILES
Blend door not working.
Wednesday, May 15th, 2019 AT 3:22 PM (Merged)
HMAC300
  • 48,601 POSTS
Try pulling HVAC fuse inside truck first it may reset and work. Then check for power. You really need a mechanic to scan for codes however to verify it is blend door problem. See pictures.
