Hi, I have a fault code 000406 related to oil temperature sensor, oil temperature warning appeared, and the indicator is not working. The car has two oil temperature sensors, one under the intake manifold and the second inside oil reservoir which is the sensor also measures the level and the temperature, which sensor is responsible for reading instrument oil temperature indicator? Need a wiring diagram to check the wires before replacing the sensor.
SPONSORED LINKS
Do you
have the same problem?
Tuesday, June 28th, 2022 AT 10:01 PM
