Will not turn off with key
LYNN1958
  • 1992 CHEVROLET ASTRO
  • 4.3L
  • 6 CYL
  • 10,000 MILES
This started after we changed fuel pump
Do you
have the same problem?
Sunday, April 27th, 2014 AT 1:21 PM
  • EXPERT
That is odd considering you never get close to the ignition switch when replacing a pump. Was anything else done to the vehicle?
Monday, April 28th, 2014 AT 5:15 AM
LYNN1958
No, we replaced the fuel pump relay too. This is driving us crazy
Monday, April 28th, 2014 AT 12:21 PM
  • EXPERT
Still, that doesn't add up. The fuel pump relay power is cut when you turn the key off. However, the ignition should be too. The only thing I can think of is the ignition switch itself.
Tuesday, April 29th, 2014 AT 4:54 AM
Recommended Guides
