Will not start
JUNKYARDDOG.321
  • 1988 FORD RANGER
  • 2.9L
  • V6
  • 4WD
  • MANUAL
  • 200,000 MILES
Had a misfire in engine. Changed coil, TFI, EEC and MAP sensors. No help. Did full tuneup, would not start unless I unplugged the MAP, then would run 1700 rpm's, very sluggish. Run code reader, came up 22, MAP sensor "out of range". Changed distributor, now the EEC and fuel sensors don't " click" when key is turned. Any ideas?
I turn the key on, dash lights work, starter cranks engine but does not fire. I tried to read the codes again. I hooked the reader to the test plug, turned the key on, turned the reader on and nothing happened. The first time I read the codes, the systems clicked and read the codes. 2nd time, the system did not click and the reader would not function.
Do you
have the same problem?
Tuesday, May 14th, 2019 AT 1:58 PM
KEN
  • ADMIN
Let check for spark at the plugs. here is a guide to help us get started:
Also will it run on starting fluid?
Thursday, May 16th, 2019 AT 11:41 AM
Recommended Guides
